Helppp..Heat Exchanger quagmire
Discussion in 'HVAC Heating & Cooling' started by a12548, May 28, 2010.
  1. a12548
    a12548 New Member
    Jul 13, 2006
    Florida
    I finally replaced my 20 yr old a/c here in Florida two yrs ago. I opted to not have a heat recovery unit on the new system. The installer, whom I cant locate or changed hands, snipped the lines dropping out of the old box. However, there are still copper lines coming out of my siding and into the defunct box. I want to take the box down and put new siding under it. I turned the valve on the box and water was dripping out very sloww from the packing nut, which i then tightened. So can it be still connected to my water heater?? Looking at my water heater I see no extra lines coming in. The other side of wall where pipes go thru siding is boxed in under new a/c so i cant see. Would an installer normally leave an active line with just the shut off outside? Anyone have any suggestions? Who would eliminate this line if it is active..a plumber or HVAC? Here is a pic...
    http://i688.photobucket.com/albums/vv248/a12548/heatexchanger.jpg
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    If they are still connected then you should see the other end of the lines at the water heater. My guess is there still connected to the heater. Most AC contractors would not touch a existing water heater. Post a picture of the heater.
    John
  4. a12548
    a12548 New Member
    Jul 13, 2006
    Florida
  5. a12548
    a12548 New Member
    Jul 13, 2006
    Florida
    I should note that the copper lines coming just after shut off valves on top of heater are for a garage sink. is that line that goes to bottom of heater the heat exchange line?
  6. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    There are TWO heat recovery lines. They are the two insulated lines. They come off the top and bottom of the heater. I also see they have valves on them. You could try just turning them off ( if they hold ) then you could then remove the lines outside. The more permanent thing to do would be to cap the lines at the heater.
    John
  7. a12548
    a12548 New Member
    Jul 13, 2006
    Florida
    Thanks John, you saved me a lot of aggravation and I appreciate you taking the time to solve this.
Similar Threads: HelpppHeat Exchanger
HVAC Heating & Cooling Insufficient heat transfer fluid flow to swimming pool heat exchanger Nov 30, 2015
HVAC Heating & Cooling Clean a Buderus GB142 heat exchanger Jan 27, 2015
HVAC Heating & Cooling Help! Exchanger on Pool Heat Pump Leaking! Mar 8, 2014
HVAC Heating & Cooling Reasons why a Heat exchanger would plug up? Feb 17, 2014
HVAC Heating & Cooling Gas furnace heat exchanger collapse? Jan 22, 2014
