Hi. I'm a newbee to this site and water treatment. Thanks in advance for your help.
My wife and I recently purchased a cottage in Wisconsin that has awful well water. There is a very strong iron taste and red (rust) staining in the sinks and toilets. The cottage has two baths. I have not run a pump flow rate yet.
The current water treatment system is set up as follows: Water Pump > Pressure Tank > Water Softener (A vintage 1984 Dicknson no longer working) > Water Heater > Culligan Medallist Water Filter (8” x 44” installed in 2001) > faucets.
I had the water tested at the Water and Environmental Analysis Lab in Wisconsin. Below are the laboratory results. Please recommend the most economical water filtration system that will provide good tasting water. I would also like to know what sequence the system should be connected from the water pump to the faucets. Do I also need a Reverse Osmosis system? Thanks!
Bacteria-Coliform - Absent
Hardness-Total - 293 mg/l CaCO3
Alkalinity - 284 mg/l CaCO3
Conductivity - 489 umhos/cm
pH - 7.99 std units
Saturation Index - 0.6 Corrosivity Balanced
Nitrogen-Nitrate/Nitrite - Less Than 0.1 mg/l N
Chloride - 4.6 mg/l
Arsenic - Less Than 0.005 mg/l
Calcium - 65.4 mg/l
Copper - 0.130 mg/l
Iron - 4.009 mg/l
Lead - 0.014 mg/l
Magnesium - 31.5 mg/l
Manganese - 0.117 mg/l
Potassium - 1.7 mg/l
Sodium - 3.6 mg/l
Sulfate - 8.3 mg/l
Zinc - 0.184 mg/l
pH - 7.99 std units
Chloride - 4.6 mg/l
Calcium - 65.4 mg/l
Copper - 0.130 mg/l
Iron - 4.009 mg/l
Lead - 0.014 mg/l
Sodium - 3.6 mg/l
Sulfate - 8.3 mg/l
Zinc - 0.184 mg/l
