Help with Kohler Shower Drain
Discussion in 'Shower & Bathtub Forum & Blog' started by Violin, May 3, 2009.
  1. Violin
    Violin New Member
    May 3, 2009
    New Jersey
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    It should not be loose. Do you have 40 SCH PVC that you are connecting to¿ Did you plumb the shower¿ PVC comes in thin wall but would be a gross oversight by a plumber to have run the drain in such pipe.
  4. Violin
    Violin New Member
    May 3, 2009
    New Jersey
    I plumbed the drain using standard PVC and have access to it through a crawl space.
    I'm not a plumber, but a pretty experienced do-it-yourselfer.
    With either 2" or 3", the fit is not at all snug and the fitting can fall right off.
  5. kingsotall
    Aug 17, 2008
    You don't have a way to test the fit on ABS do you¿ I don't know why this would make a difference but it's worth a shot.
  6. Violin
    Violin New Member
    May 3, 2009
    New Jersey
    Not without buying a length of it. I've already built the shower pan around the Kohler drain.
Similar Threads: Help Kohler
Shower & Bathtub Forum & Blog Help, cast iron install questions. Kohler villager Nov 2, 2015
Shower & Bathtub Forum & Blog ***Kohler Shower Valve replacement ***HELP Sep 18, 2014
Shower & Bathtub Forum & Blog Need help fixing a Kohler shower faucet Jun 20, 2014
Shower & Bathtub Forum & Blog kohler tub spout replacement help! Apr 18, 2013
Shower & Bathtub Forum & Blog Help with Kohler Mistos Install Nov 19, 2012
