Help with garage plumbing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 67restoproj, May 1, 2008.
  1. 67restoproj
    67restoproj New Member
    Apr 29, 2008
    Langley BC Canada
    Building a garage with a 2 piece bath and was wondering how you bring your water and sewer up to the finished slab. Also how to tie in for the vent. I appreciate your help. I am also going to make a run down to the library...Thanks!!!
  2. 67restoproj
    Apr 29, 2008
    Langley BC Canada
    The black lines on the sides of the forms are finished slab height...
    [​IMG]
  4. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Around here in Florida, they plan what all the plumbing should look like when it's all done, then just do it in place, brace it so it doesn't move, and pour the slab. Horizontal positioning is done using strings from reference marks on the batten boards or footer forms, and verticals just go up well above the finished height -- they're capped and trimmed to finish height later. I'm amazed by the precision -- pipes come through the finished slab right where they need to be when walls go up later, WC stubs are 12" from finished wall, etc., all to within 1/8" or so.
    Supply lines are insulated where they're under the slab, waste lines are insulated to provide tweaking gaps between the pipe and the slab. Some waste & vent lines are sometimes left very long for static pressure testing. Needless to say, all pressure testing (supply and DWV) is done before the slab is poured. I'll look around for a home under construction (a rarety here these days) and post a pic if I can find one.
Similar Threads: Help garage
Plumbing Forum, Professional & DIY Advice Help with DWV Layout for detached garage Nov 6, 2015
Plumbing Forum, Professional & DIY Advice Need help draining sink in garage Sep 12, 2015
Plumbing Forum, Professional & DIY Advice Help! No Water From Garage Faucet Sep 3, 2007
Plumbing Forum, Professional & DIY Advice Help plumbing my new garage. Sep 25, 2005
Plumbing Forum, Professional & DIY Advice Chipped shower tile....what to do help!! Yesterday at 6:09 PM
