Help with copper pipe leak above water softener
Discussion in 'Water Softener Forum, Questions and Answers' started by simps911, May 24, 2013.
  1. simps911
    simps911 New Member
    May 24, 2013
    Indiana
    Hi,
    I hope that this is the right place.
    Right above there water softener there are three valves. The valve on the right seems to be leaking. I am not sure if it is the nut, or the actual copper pipe where it goes into the female end of the valve.
    I tightened the nut and it seems to have stopped.
    My question is, could it be possible that when the water softener kicks on it loosened up the nut, in turn causing the leak?
    If not, or maybe in addition, should I reinforce the opening at the male/female portion of the copper pipe?
    Thanks for your help
  2. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Leaks in these older "gate valves" are common, and the usual (temporary) fix is to tighten the "bonnet" or "packing nut" as you have done. Sometimes the position of the valve (fully open or not) affects the leak. Longer term, you can re-pack the valve (a fairly simple operation) or replace the valve with a new ball valve. If you're going to replace the valve, you might as well do all 3, basically building a new bypass-valve assembly. But, if you've stopped the leak with a simple tightening of the packing nut, you're probably good for another 10 years.
Similar Threads: Help copper
Water Softener Forum, Questions and Answers Softener, Just need some advice and help... Feb 9, 2017
Water Softener Forum, Questions and Answers HELP NEEDED! Update whole-house water filtration system (well water) Feb 6, 2017
Water Softener Forum, Questions and Answers New Fleck 5812 SXT - Need help with settings Feb 1, 2017
Water Softener Forum, Questions and Answers Need help tweaking fleck 5600sxt settings Jan 28, 2017
Water Softener Forum, Questions and Answers REQUEST HELP WITH SYSTEM DESIGN AND SOFTENER SETTINGS Jan 25, 2017
