Help Sanke problem!!!!!
Discussion in 'Shower & Bathtub Forum & Blog' started by tazzmann74, Jan 22, 2006.
  1. tazzmann74
    tazzmann74 New Member
    Jan 22, 2006
    I snaked my type and to my surprise the snake got stuck will not come out or even go in farther!! I do not know what to do to get it out. Now i have a clog by it which interferes with the toliet and washer working as well as the tub. PLease help!!!!!!!!!!! :confused: :confused:
  2. justinhammond
    justinhammond New Member
    Jan 21, 2006
    If the pipe is PVC find when the snake is stuck (by sound) and cut the put a foot or so back so you can free the snake. You can then repair the pipe witha repair coupling or remove and replace the section of the pipe that is giving you problems all together
  4. Cass
    Cass Plumber
    Nov 12, 2005
    How old is you house?
    Are you on a basement, crawl space, or slab?
  5. hj
    snake
    I wondered what a "sanke problem" could be. You do have a problem, can you run the snake in reverse while pulling on it? Could you be caught in a backwater valve? If neither, then your only recourse is to dig it up, but then you will probably have to do that anyway to find out why it happened at that spot.
  6. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    roots, roots, roots
    you have gotten into roots if you are
    out into the yard......if you have gone out that far
    going back and forth might get it unstuck....
    but basically you have gotten youself into a mess..
    call a drain professional.
  7. hj
    snake
    In addition to my previous answer, the last one reminded me of a situation from years ago. A drain cleaner was called to snake the washer drain. His snake also got wound up and could not be removed. He told the customer that it was their responsibility to get the snake out or he would have to charge them for it. I dug up the exterior main cleanout where his 1/2" snake had tangled into roots. Pulled the kinked and twisted snake out and left it on the ground and then did a proper snake job on the sewer.
Similar Threads: Help Sanke
Shower & Bathtub Forum & Blog Help identifying shower handle extension Yesterday at 9:13 PM
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Thursday at 6:36 PM
Shower & Bathtub Forum & Blog Bathroom remodel issues, need help and advice Mar 16, 2017
Shower & Bathtub Forum & Blog Help appreciated! : stripped Moen retainer pin / clip Feb 25, 2017
Shower & Bathtub Forum & Blog I need help identifying a Roman tub fixture Feb 25, 2017
