Charlie Bosco
Active Member
This is a photo of the current system layout that I inherited with the home I purchased 3 years ago. Luckily its all inside a Pump Shed. I also have it Humidity (40%) controlled for additional storage. Its a messy layout!
The water flows like this.
Jet Pump and Pressure Tank
50 micron spin down filter ( I added this)
GE Canister Filter with 5 Micron Carbon Element
Kinetico 2060S Water softener
GE Canister Empty (used for chlorine tablets to backwash the original Carbon Tank)
Katalox AIO (I replaced my original Carbon Tank, show in photo, with this)
House
I am rebedding the old Carbon Tank and plan to add it after the Katalox as a final scrub before it goes to the house.
Here is where I need help.
1. I plan to replace the first GE canister filter with a Big Blue 20" with a bottom drain. Not sure the best cartridge to use so I'd like opinions.
2. I feel there is no need to keep the empty GE Canister that precedes the Katalox filter. If I need to introduce anything like Chlorine I can use the big blue and bypass everything till it gets to its intended place. Thoughts?
3. Any benefit to changing whether the softener is before or after the Katalox?
House
