TFastle
I am having a pool put in. I told the pool company I would supply the Natural gas to the equipment pad. It's a 250' run. It will be high pressure (2psi and then a regulator at the pad) and go directly from the meter to the pad. I also hope to put a grill and natural gas torches at the pool off this line later, a total of about 440,00 btu's. My plumber is running 1" plastic (like pex) and says it will be plenty. After asking him about the calculations I am losing confidence. Can someone tell me how many btu's I will have available with this set up and, most importantly, will it be enough???? There are no other legs to the system, just a straight run right out of the meter. I tired calculating it myself but am not sure I am doing it right. Any help would be GREATLY appreciated! Thanks!!!
