Help me, I'm dumb (Delta shower cartridge issue)
justintime28
Arkansas
I need some help, I’ve exhausted everything I know and can’t figure this out.
I’m trying to install a delta shower cartridge (MODEL#: RP46463) into r22000 valve body and no matter what I do the water just comes out full force from the shower head like the cartridge is turned fully on.
I’ve installed delta cartridges before and never had this issue. Online I can’t find anything that helps either.
Things I have checked/tried:
Turned the part the handle attaches to on and off (it seems like the flow changes slightly around the middle of the range but is basically full force no matter how it’s turned.) I haven’t fully put the handle on yet, but I don’t see how that would make a difference.
Tried two different cartridges multiple times with and without plumbers grease on the o rings. Same result no matter what. I am able to get it seated properly as far as I can tell based on past experience and videos I’ve seen.
Flushed the valve out with no cartridge in it.
Checked to make sure cartridge is compatible with valve. As far as I can tell they are. Trim kit is T27867 and valve is r22000. I have a picture showing they are compatible.
I’m sure it’s gotta be something stupid I’m doing but I have no clue. Could water be getting past the cartridge in the valve that I’ve circled in the picture? It doesn’t seem like my cartridge is covering that opening going up to the diverter.
Assuming its genuine Delta parts not chinese junk . it can only be installer error or defective , wrong valve or cartridge. the look inside of yours with the seats and plastic covering the port looks odd but I dont think its suggests a wrong cart. or installation. Sorry no help . get on the horn with Delta they will set you straight
Anthony M
Kingsport, TN
Is it possible you have the wrong replacement cartridge? Closely compare the old with the new. It may be that the cartridge you are using is a little shorter than the original (therefore the cold and hot water cartridge taps are not reaching the ports in the valve body and water is completely bypassing the cartridge).
