Help me identify this shower cartridge!!
Discussion in 'Shower & Bathtub Forum & Blog' started by krystal138, Aug 13, 2012.
  1. krystal138
    krystal138 New Member
    Aug 13, 2012
    Alberta
    My house was built in 2009, about 6 months ago the water in the shower went from hot to warm. I called a plumber and he said i need to order a new cartridge. The problem is there are no markings on the shower or any of the parts and I have not been able to match it up in any stores or online. Please help me identify this shower/cartridge!
  2. allforone
    allforone New Member
    Nov 12, 2012
    Toronto, ON
    I have the same problem. I turn the mixer to the hottest position, but the water is still a little warm. The cartridge is almost the same. I can only identify "Selection" on the cover, nothing else. But nobody ever heard of that brand.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    You get A+ for all the right photos! I can't ID it personally, but someone will. Stay tuned!!!
  5. Towers Plumbing
    Towers Plumbing In the Trades
    Nov 13, 2012
    Salt Lake City, UT
    Moen Exactemp
    Those cartridges look like an older style of the Moen ExactTemp® shower valves. The large white valve with the screens is the thermostatic mixing valve and the second valve is most likely a ceramic volume control cartridge.
    mixing valve cartridge $120
    http://www.moen.com/shared/docs/exploded-parts-views/s3371pt.pdf
    volume control cartridge $22
    http://www.moen.com/shared/docs/exploded-parts-views/s3600pt.pdf
    Note the second page for valve built before 2009. Older model cartridges can still be ordered but not directly through Moen. It goes through Moen but my distributor is the only way I can order it. Might want to check with a local plumbing supply warehouse.
    Good Luck.
  6. shaolin_dragon
    shaolin_dragon New Member
    Oct 6, 2006
    VA
    Negatory good sir. That is not a Moen. The trim is all wrong and the lower cartridge on the 2 handle 1/2" ExactTemp was a 1248 roman tub cartridge. The newer 3/4" exactTemp do not have a dual handle configuration. Only single.
    Good luck on the hunt.
  7. mikestahlman
    mikestahlman In the Trades
    Sep 24, 2013
    Longmont, CO
    I just ran into this same cartridge! Did you ever get to the bottom of it because I am having a hell of a time finding the brand or model. Thanks!
Similar Threads: Help identify
Shower & Bathtub Forum & Blog I need help identifying a Roman tub fixture Feb 25, 2017
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog Can anyone help identify this Shower Faucet? Oct 21, 2016
Shower & Bathtub Forum & Blog Help identifying brand to find parts. Oct 9, 2016
Shower & Bathtub Forum & Blog Need Help identify in order to replace Thanks! Oct 6, 2016
