Help identifying shower valve
Discussion in 'Shower & Bathtub Forum & Blog' started by seeker_moc, Apr 29, 2013.
  1. seeker_moc
    seeker_moc New Member
    Apr 29, 2013
    FL
    I'm trying to fix up the kid's bath in a house I recently bought. The shower/tub valve still works, but the trim is in bad condition and I'd like to replace it. I'd rather not have to rip up the wall to put in a new valve, but I can't find a trim kit that fits.
    At first I though it was an old Moen standard valve, as it's rotate for temp and pull straight in/out for volume, and the screws at the bottom of the faceplate are at 7 and 5. However, Moen trim kits don't fit, the hole in the center for the valve stem is too small, and the holes in the faceplate are just a tad too close together.
    I tried a kit for a Delta 600 series, and the faceplate actually fits perfectly, but the knob doesn't. I might keep this kit just for the faceplate, but I'd rather find the actual correct kit instead of just an 80% solution.
    The valve stem assembly is entirely plastic, with a round gear where the knob attaches, and three screws that attach it to the valve. The house was built in '85, and I assume the valve is original to the house.
    I'd greatly appreciate any help in identification.
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    It is a Bradley Cole, or... Briggs, Sayco, Kohler, Federal, Powers-Gavin, or Vance (& perhaps others). Reuse the outer grey plastic piece.
  4. seeker_moc
    Apr 29, 2013
    FL
    Thanks. So basically, it's just an old cheap generic valve? Do you know of any trim kits (preferably brushed-nickel) that would fit this?
  5. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    It isn't all that unusual for a manufacturer to build up a valve based on parts of another. I suspect you will find even chrome trim tough to come up with and I don't think all the versions use the same trim.
  6. seeker_moc
    Apr 29, 2013
    FL
    Ok, thanks again for your help.
  7. BWDuty605
    BWDuty605 New Member
    Jul 27, 2014
    Sorry to dig up this old thread, but I'm hoping for some help. I have an identical shower valve to yours and my hot water stopped working. I managed to fix it using a Faucet Single Control Cartridge - Bradley Cole which was extremely difficult to find at a local retailer, I tried all the big chain home improvement stores and and even a few mom and pop operations in older areas of town since this is quite an old configuration. Anyway, my problem is the backsplash/trim piece was already in bad shape and fell apart. Even worse, both mounting screws fell into the wall! I can't seem to find a square piece like mine anywhere, even on the internet. I suppose I'll need an alternative, what did you end up using? I'm hoping for the cheapest fix possible, as I live in an apartment and just want this taken care of so I don't get charged for it.
  8. BWDuty605
    Jul 27, 2014
    I think I answered my own question, I was having such a hard time finding it because I was looking for "face plate" and "trim piece" but evidently they are called "escutcheons". The mounting holes are set at 1-11/16" apart and the hole for the valve is 1-3/4", so I bought a CHROME ESCUTCHEON for SINGLE LEVER DELTA SHOWER VALVE and Delta RP196 Screws (Set of 2) since my valve sits about 2-1/2" to 2-3/4" back in the wall. I think I will be set, will find out when they arrive! Got the whole fix for less than $20 .
Similar Threads: Help identifying
Shower & Bathtub Forum & Blog I need help identifying a Roman tub fixture Feb 25, 2017
Shower & Bathtub Forum & Blog Help identifying brand to find parts. Oct 9, 2016
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
Shower & Bathtub Forum & Blog Help identifying shower diverter stem Sep 23, 2016
Shower & Bathtub Forum & Blog Help Identifying my shower valve. Sep 8, 2016
