Help identifying P-trap replacement/sizes
DIY_Novice
Hi all,
I've pulled the tub and replaced all the sub-floor in my bathroom tear-out, now I need to tackle the plumbing. Since I have it all open I feel silly not replacing the tub brass P-trap + drain/overflow. I'd feel a lot better replacing with new if it's not going to be a major PITA. I've attached some images to this post.
From what I can tell it's a regular 1-1/2" brass overflow and waste drain that hooks into a brass P-trap that starts at 1-1/2" slip nut joint (marked "A") to 2"(?) slip nut joint (marked "B"). The nut at location marked "B" is huge, don't have a plumbers wrench large enough to get around it even. From there the other end of the trap joins a threaded steel/iron pipe at location marked "C" and goes onto the rest of the sewer plumbing marked "D". I measure the pipe running "C" to "D" at roughly 2.5" diameter (8" circumference measured w/ a string). I 2.5" OD sounds about right for a 2" ID iron pipe? No way it's 2.5" pipe size in a residential home, I figure.
Any recommendations here? I don't mind to replace everything with PVC but I'm not sure how I feel about those rubber couplings leaving a small joint/crease where the two pipes meet, I hate slow drains and don't want any excuse for hair or junk to build up at a seam.
House was built in the late 60's if that helps identify anything.
1) If I wanted to go PVC - could I get a 2" female iron pipe (FIP) waste connector? Slip nut on the other side to slide into 1-1/2" PVC and do the rest of the plumbing in 1-1/2" PVC? Can't seem to find a waste connector like this anywhere.
2) If I wanted to replace straight up, I believe it's this? https://www.supplyhouse.com/Everflo...MIiNiR3qPK7wIVh9XACh22bQ-pEAQYAiABEgIyiPD_BwE
3) Alternatively, should I just pull the 1-1/2" drain plumbing and take a look in the trap? If it's not corroded or rough, just leave it?? Are the slip nut washers common sizes where I could buy a new one to replace it at the joint of "A"?
Advice is gladly welcomed, thank you.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
You should scrap out all the galvanized drainage piping and fittings.
The old durham cast iron fittings and piping are so old that now is the time to do the replacement.
This looks like second floor. We always use cast iron where noise can be an issue. Though, in the horizontal plane, not much noise from plastic.
Yes, common slip joint washers are still available in square cut, but modern waste and overflow use beveled washers.
Slip joint connections must remain accessible permanently for future access or use glue joint waste/overflow if you don't want to rely on access panel.
In confined space like you have, I recommend you hire a licensed professional.
