Help identify this blue pipe?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by thebordella, Aug 31, 2010.
  1. thebordella
    thebordella New Member
    Nov 9, 2009
    Ithaca, NY
    Hi,
    I am working on a project at home that requires me to tap a water supply for an icemaker. I do not want to use a saddle-valve. Instead I want to use a tee. I already have a tee and have assembled the line from the tee to the icemaker line (braided steel compression line). But now I actually need to install the T inline with existing water supply.
    The fridge is right beside the well water supply. In the attached picture you can see the existing pipe work in the well room. It consists mostly of a blue-ish piping with short sections of a white-ish piping. I had thought this piping was CPVC which I know is used elsewhere in the house (although not blue).
    I bought a cheap pipe cutter (the kind you squeeze like scissors) and practiced on a few sections of scrap 3/4 inch known CPVC. No problem. But then I tried to cut the blue piping for real, and the pipe cutter hardly made a scratch. I squeezed hard and still nothing. Now I'm stumped.
    Is this blue pipe not CPVC and if not, what is it? There seem to be no visible markings on the exposed sections. Am a little stumped why I can't cut this stuff and if not, how to tap the well room for the icemaker line. Thanks for any ideas!
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    It is sch 80 pvc piping you need a hacksaw to cut and the proper glue to install a tee !
    Out of the correct material not cpvc ! !
  4. thebordella
    Nov 9, 2009
    Ithaca, NY
    Thank you!
    Can you tell me what the proper glue and tee would be? I would like to connect the tee to a 1/2 inch CPVC stub because that is the assembly I have already put together. (The stub connects to a shut off valve which has a compression connector to the icemaker line. Again, this is already assembled.)
    If there is more than one way to insert the tee into this sched 80 PVC then I would like to know the "easier" way even if that means buying more costly parts. Thanks!
  5. hj
    SCh 80 PVC is gray, not blue and it has markings all along its length. The picture is not good enough to determine whether it is blue or gray, but until you know the material, you do NOT know what kind of glue to use, but PVC and CPVC are different sizes and are not compatible as far as cements are concerned either, even if you could get them to fit together.
  6. thebordella
    Nov 9, 2009
    Ithaca, NY
    This morning I took a flashlight and contorted myself around the well room to find any signs of markings on a section of the pipe in question. A ha!
    The "blue" pipe is in fact marked as "CPVC Gray". I take it this means it is Schedule 80 CPVC. It really does look blue in person. It is old, maybe the color has shifted over time. Or maybe I need to see an eye doctor. Anyway, my existing assembly to connect up with the ice maker line is made of CPVC pieces, so that's good.
    It sounds like I should just be able to hacksaw the Sch 80 CPVC and install a tee, presumably using CPVC solvent (already have some)?
    Altermatively, I have been known to use the occasional Sharkbite connector. They do make a tee. Does anyone know if a Sharkbite can accept Schedule 80 pipe?
  7. hj
    I hope it is NOT sch. 80 CPVC, because if it is the opening inside the pipe may be miniscule. It is probably just gray CPVC, like PEX comes in various colors also. The o.d. of the pipe determines whether a Sharkbite will work, and ALL cts sized CPVC, (copper and PEX also), has the same o.d.
  8. thebordella
    Nov 9, 2009
    Ithaca, NY
    Thanks for everyone's help. This morning I cut into the pipe in question with a hacksaw and installed a Sharkbite Tee. Worked like a charm. I only have one small little issue that I will post about in a new thread.
    BTW, it turns out that after all this questioning, the pipe really was just Sched 40 CPVC. No idea why it was so much harder to cut with my cheap pipe cutter than new CPVC. And no idea why it is blue (or gray).
  9. jeffeverde
    jeffeverde Member
    Sep 21, 2009
    L.A.
    PVC can get brittle and hard with age - to the point that it will shrapnel rather than cut with a "knife-blade" cutter.
Similar Threads: Help identify
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Tuesday at 3:53 PM
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Help identify Delta faucet Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Help identifying faucet brand! Dec 17, 2016
