help how to use a snake
Discussion in 'Toilet Forum discussions' started by mollycunneen, Jun 21, 2006.
  1. mollycunneen
    mollycunneen New Member
    Jun 21, 2006
    Help Help, the toilet is stopped up. :eek: I tried a ball plunger, to no avail. I now rented a snake, read many on-line instructions. I can not get the snake to go more than 3 inches into the hole of the toilet. I crank, one way then the next, push and turn the end around with all my might. Nada! I can keep the snake for 20 more hours before paying another $25. Does anyone have any ideas?
  2. jimbo
    jimbo Plumber
    Is this a toiler auger which has a crook on the end? This little bend gets the tip of the auger pointed into the trapway. The you push on the handle while turning, and it works its way in. If you have a conventional hand auger in a can, you will have a hard time putting it thru the toilet.
  4. hj
    snake
    Which way does the opening in the bottom of the toilet face? If it turns towards the front, you will proabably never get the snake through it. If it goes towards the rear, and you have the proper snake, it should slide right in. If you have a sink drain snake, the only thing you will do is damage the finish in the bottom of the toilet.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Since you rented it I will assume you have the wrong snake as I don't think rental stores rent toilet augers. You can buy one from a big box store fairly inexpensively. If you cant get the auger through call a plumber.
  6. prashster
    prashster New Member
    Dec 7, 2005
    Gotta feed it bit by bit. Pull out about 1ft fm snake coil. Crank and push at same time. Pull out another 1ft from coil. Repeat.
  7. sendec
    sendec New Member
    Mar 28, 2006
    I have had the best results with the aforementioned toilet augers. I'm sure I paid less than 10 bucks for it at the local hardware store. Real lifesaver.
    Now if someone could make one with some form of rust-free finish.......
  8. hj
    snake
    __________________
    (important note: I'm not a pro)
    You must also not have ever snaked a toilet. That is a guaranteed way to scratch the finish in the bottom of the toilet, besides not curing the problem.
  9. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    My 2 cents worth is to put a bend right behind the hook. The flopping action will help to make a quick turn in the right direction.
    Also don't lean on the handle. Just nice steady pressure and turn it to the right 3 or 4 turns and then the other way, back and forth, and it will make its way through.
Similar Threads: help snake
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Feb 18, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Help: Trickle sound and smell from Cimarron Jan 21, 2017
