help hot water gets cold a few seconds
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mekdek, Jan 31, 2008.
  1. mekdek
    mekdek New Member
    Jan 28, 2008
    I have a submergeable pump well system. Down in the basement is where the line coming in leads to a air tank pump. the system uses air pressure to pump though the line from the tank. When the lines need more pressure the tank pump kicks on and once pressure to about 80 lb the unit kicks off until 20 lb pressure. The problem is while in the shower. I can feel a 1 second surge when the tank kicks on. While the pressure is rising until kickoff my hot water is ice cold. The tank kicks off and them I am back to warm water. How can I remedy this? mek@duo-county.com
  2. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    The first step would be to call in someone who knows something about pumps. Normally, pump range is 40-60 lbs. or somewhere in that range. You've got far too much differential.
    Another help would be a larger tank, and it's possible that your tank is no longer functioning well - the pressure tank should be checked for correct base pressure.
    If you have a pressure-balancing faucet in the shower, chances are the pressure variation is more than it can handle, or you're getting an initial surge from the pump when it kicks on.
Similar Threads: help water
Plumbing Forum, Professional & DIY Advice Help sizing kitchen sink/washer/dishwasher water supply Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Whole House Water Filter HELP...super confused Dec 28, 2016
Plumbing Forum, Professional & DIY Advice Turned one shut off valve now there is NO water in bathroom sink. HELP Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Need Help With Kitchen Water Supply Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Banging/Knocking sound when tenants flush. Water Hammer Arrestors have been installed. HELP Please! Dec 8, 2016
