Heat Pumps/Well Pump Problem
Discussion in 'HVAC Heating & Cooling' started by plantnerd, Dec 8, 2009.
  1. plantnerd
    plantnerd New Member
    Sep 12, 2009
    Wichita, KS
    Hello
    We have 2 heat pumps fed by a 1/2hp well. The "control board" for the well went out today while we were out, thus no water feeding the heat pumps. It's been around 30 deg here today.
    We replaced the control board for the pump, so we now have water, but I cannot get water through the heat pumps. I know there is no water because I have a bypass to the waste line and don't get anything when the system is running. The heat pumps are fitted with Taco valves on the water out side. Any help? It's supposed to be a high of 15 deg here tomorrow, and I really don't feel like feeding a woodstove all night.
    Thanks
  2. burleymike
    burleymike New Member
    Nov 4, 2008
    Idaho
    If I understand what you are saying, you are bypassing the heat pumps and dumping the water directly to the waste line? Do you have any water going to the waste line?
    Is the pump a submersible or a jet pump on a shallow well? If it is not a submersible the pump might have lost it's prime. Do you have a pressure gauge on the outlet of the pump?
Similar Threads: Heat Pumps/Well
HVAC Heating & Cooling Radiant heat and domestic water on same system? Feb 13, 2017
HVAC Heating & Cooling Apollo hydro heating Jan 30, 2017
HVAC Heating & Cooling Heater Jan 28, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling Is my AC Heater bad or the outlet? Jan 15, 2017
