heat pump??
Discussion in 'HVAC Heating & Cooling' started by possum, Mar 12, 2007.
  1. possum
    possum New Member
    Feb 20, 2006
    western pa
    how can I tell if my furnace has a heat pump on it it says it is a forced air high efficient natural gas furnace but says nothing about a heat pump on it. It was installed in 2000
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    If it has a heat pump, it will have a system that looks a lot like an air conditioner, with a unit outside that looks like a condensing unit but is really an evaporator, that runs when the weather is cold. The condensing unit might be a combination condensing/evaporating unit. The telling point is that it will be running while you should be heating.
    It is very unlikely that you have a heat pump without knowing it.
  4. Rancher
    Rancher Guest
    Where do you live and what do you use for cooling? That would determine if you might have a heat pump or not.
    Rancher
  5. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Read the plate on the outside unit, and look up the model at the manufacturers's site. In no luck, call a local dealer of the brand with the model #.
  6. jimbo
    jimbo Plumber
    San Diego, CA
    It is not common to use a heat pump in conjuction with a gas furnace, although it can be done. Look at the thermostat. A heat pump will usually have an orange wire for the reversing valve.
Similar Threads: heat pump
HVAC Heating & Cooling Rheem heat pump Nov 27, 2016
HVAC Heating & Cooling Start up noise Heat Pump Aug 21, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
HVAC Heating & Cooling Odd Heat Pump Behavior Feb 3, 2016
HVAC Heating & Cooling Multi zones HVAC system not pumping heat to first floor Mar 23, 2015
