Heat pump service disconnect
Mrbeing123
Louisiana USA
The package heat pump in question require two circuits. Is it usual for an electrician to run one circuit large enough to run both to a loadcenter by the package unit and then take two branch circuits off of there? And then use this load center as the equipment's service disconnect?
If I understand this correctly(and please let me know if you think I don't)...
Run 2-#2 75c THW and 1 - #8 bare in 2" pvc conduit from the outside loadcenter/meter base on a 100amp breaker
to
say an Eaton 125 Amp 4-Space/Circuit CH Type Main Lug Loadcenter
and and from this, run a whip with the two circuits with wire sizes and MOCPs per manufacturer's specs
JWelectric
Electrical Contractor/Instructor
North Carolina
#2 is good for 90 amps and the #8 can be a green insulated it does not need to be bare
