Heat loop at water heater, other ? too
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edwardh3, Mar 10, 2008.
  1. edwardh3
    edwardh3 New Member
    Jan 5, 2008
    South Carolina
    many sites say to put a heat loop on the tank style water water heater to stop the rise of hot water from the heater.
    1. do I need it on both the hot and cold connections?
    2. how high must the loop be (how much of a loop up then back down)
    3. Are there advantages/ disadvantages of flex copper vs stainless steel mesh flex lines other than cost - which is more reliable?
    4. Is there one fitting- not two or 3 that I have to solder together- that will screw into the female IPS hole in the heater top, that the flex connections will then screw onto?
    Thanks.
  2. rudytheplbr
    rudytheplbr 36 Journeyman Plbr
    Sep 29, 2006
    New ****, remodel ****, repair plblg
    Ketchikan, Alaska
    Water heater conns.
    The connections to a water heater/storage tank are always thread connections (unless you have a copper tank w/solder conns). The only thing you may need to solder is a male adapter on your cold water supply, and one on the hot water dist. line.
    I reccomend using brass nipples out of the tank holes w/flex connectors to Hot and Cold.
    Good Luck.
    Rudy
  4. edwardh3
    edwardh3 New Member
    Jan 5, 2008
    South Carolina
    thanks
    I already have the male adapters in place. just wondering about the heater end.
    any idea on loop heigth- or where I could go to look it up?
Similar Threads: Heat loop
Plumbing Forum, Professional & DIY Advice 1/2" hydronic heater on 3/4" loop Oct 9, 2015
Plumbing Forum, Professional & DIY Advice heat to second zone not making the loop Sep 22, 2014
Plumbing Forum, Professional & DIY Advice Passive recirculation loop with mixing valve at heater? May 5, 2014
Plumbing Forum, Professional & DIY Advice Any way to have a gravity recirc loop with a tankless water heater? Jul 4, 2012
Plumbing Forum, Professional & DIY Advice What water heater for gravity loop? Mar 31, 2009
