Hardwire to dishwasher
Discussion in 'Plumbing Code Questions' started by Maryn, Apr 27, 2012.
  1. Maryn
    Maryn New Member
    Apr 27, 2012
    LA
    I guess my question is more of an electrical question, sorry: I've replaced my old dishwasher with a new one. The old one was hardwired and the new one has a plug. What do I do with the old hardwire? Do I trim it, cap it, take it off the circuit entirely? As of now it's capped and shoved behind the new one but that's probably not the right thing to do. Any advice would be great! Thanks!
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The cable should be removed back to the junction box which it originates from.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Why not just connect the hard wire to a outlet and plug the dishwasher into it?
    John
  5. Maryn
    Maryn New Member
    Apr 27, 2012
    LA
    THanks John and cacher_chick. John, I think you are right in that I should use the existing hardwire. It's safer.
  6. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Hard wiring a DW makes no sense. If it did, we'd hard wire electric ranges, and clothes dryers. Simply put an outlet box in the wall behind the DW, run the present wiring into it and install a socket. It you ever need to remove the DW for repair or replacement, this will greatly simplify the process. You will want to leave enough wire on the DW to allow it to slide out for servicing and still be connected. Same with the water line and drain. There's plenty of space under the DW to have the extra wire and water line.
Similar Threads: Hardwire dishwasher
Plumbing Code Questions Air Gap for dishwasher Jan 25, 2017
Plumbing Code Questions Existing dishwasher setup OK? Nov 14, 2015
