hansgrohe axor pull-out kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rbechhoefer, Nov 1, 2009.
  1. rbechhoefer
    rbechhoefer DIY Junior Member
    Nov 1, 2009
    U.S.
    The 3/8" supply line inside the faucet body appears to be leaking. Is there a way to remedy this? Is there a way to access the interior of the faucet body to tighten the supply hose?
    The seal below the cartridge appears to be in good shape. If replacing the seal doesn't remedy the situation, I thought replacing the supply line may. Just not sure if that is possible.
    Thank you!
  2. EuroPlumber
    EuroPlumber In the Trades
    Mar 4, 2009
    Tech Support
    North America
    The hoses are most likely threaded into the faucet. If you don't hold back on the hose when tightening them to the supply stops then you have the possibility of unscrewing them from the faucet while you are tightening to the stop. Turn off the stops, disconnect the hose from the stop, check if hose rotates freely, tighten clockwise, and reconnect to the stops, but be sure to hold the hose so it does not spin. Turn on the stops and check for leaks.
    If you still have a problem, contact Hansgrohe's technical support. They can help you resolve the problem. Hansgrohe's number is 800-334-0455
Similar Threads: hansgrohe axor
Plumbing Forum, Professional & DIY Advice Bathroom Faucet, Hansgrohe Axor Arco Oct 13, 2013
Plumbing Forum, Professional & DIY Advice Offset p-trap, Hansgrohe fixture, Ikea Sink -- Questions Sep 4, 2015
Plumbing Forum, Professional & DIY Advice Hansgrohe 04233 shower control valve problem Apr 19, 2015
Plumbing Forum, Professional & DIY Advice Best mounting depth for Hansgrohe i-Box? Apr 11, 2015
Plumbing Forum, Professional & DIY Advice Ugh - Contractor tells me he is unable to install my expensive Hansgrohe Citterio tub spout Jan 24, 2015
