Ground wire confusion
Discussion in 'Electrical Forum discussion & Blog' started by a12548, Jun 10, 2010.
  1. a12548
    a12548 New Member
    Jul 13, 2006
    Florida
    I re-sided my home and will reattach the ground wires back to house. Can I group all 3 ground wires together on clips? Can I use the regular plastic cable clips? They all lead to the hose bib, and they are attached with straps that tighten with a screw. Im replacing hose bib, does Home Depot sell those straps?
    Also my new air conditioner seems to have an old ground wire which is loosely clamped to a line coming out of house then leads to just a ground block mounted on the house that ends there, nothing attached to it. I suspect its left over from my old unit, how are units such as Goodman grounded?
  2. Lightwave
    Lightwave New Member
    Aug 20, 2007
    Vancouver, BC
    From your description it doesn't sound like your grounding is code compliant or particularly safe. House ground wires must be connected to a good quality ground connection--a hose bib doesn't count. At minimum, you'll need a ground rod.
    Ask your local electrical inspector what the code requirements are in your area for grounding.
  4. hj
    What size are the wires? That connection sounds like an old telephone ground line.
Similar Threads: Ground wire
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Extending ground wire from main panel Jun 11, 2016
Electrical Forum discussion & Blog Installer cut off SER ground wire May 20, 2016
Electrical Forum discussion & Blog Need recommendation: Underground splice kit, 2 AWG, aluminum wire Jan 9, 2016
Electrical Forum discussion & Blog No grounding wire... Jun 22, 2015
