Ground Rod Placement
Discussion in 'Electrical Forum discussion & Blog' started by SETexas, May 6, 2011.
  1. SETexas
    SETexas New Member
    Apr 24, 2011
    Southeast Texas
    I was just wondering if I needed another ground rod at my shed because of how far my shed is from the main ground rod at the house. House electricity.jpg
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Hello SETexas,
    Would not hurt for extra lightening protection.
    You can never have to many grounds, In Texas. The Deeper the better.
    Have a Great Day.
    DonL
    P.S. Are You asking, about needing to meet electrical code ?
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    The distance has nothing to do with it.
    If the shed has a sub-panel in it then it REQUIRES a grounding electrode. If it is only fed with a circuit then no ground rod is required, or needed IMO.
    In typical AC building wiring ground rods serve VERY little purpose.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Yea, what he said.
    You can only have a single circuit in an outbuilding, UNLESS you have a subpanel in the outbuilding, which would then require grounding rods.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    As pointed out rods are required as well as an equipment grounding conductor installed with the feeders.
    Isolation of the neutral from the EGC and the grounding electrode conductor and panel enclosure.
  7. SETexas
    SETexas New Member
    Apr 24, 2011
    Southeast Texas
    OK, subpanel you mean a breaker box? Yes I have a breaker box in shed fed from 100amp breaker in house.
  8. jadnashua
    that is what is called a subpanel.
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Although called a “subpanel” in the trade there is no such item as “subpanel”
    To be correct it is a remote distribution panel.
    Call it whatever trips your trigger but it will require a grounding electrode system
  10. SETexas
    SETexas New Member
    Apr 24, 2011
    Southeast Texas
    Thank You All!
  11. hj
    And if your dirt is very dry, you may need two ground rods 10' apart.
  12. frenchelectrican
    frenchelectrican Electrician
    Jun 16, 2007
    Master Electrician
    NE Wis / Paris France { In France now }
    Most place will ask for two ground rods unless you get someone with specal tester to verify if the ground is under 25 ohms { that can get very expensive to do that } so it cheaper just get two ground rods and be done with it and keep the rods at least 2 meter apart { 6 feet } or more.
    Merci,.
    Marc
Similar Threads: Ground Placement
Electrical Forum discussion & Blog Creating a new earth connection for grounding an outlet Sunday at 5:01 AM
Electrical Forum discussion & Blog Electrical panel- no ground Feb 1, 2017
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Panel ground rod. Nov 11, 2016
Electrical Forum discussion & Blog Wiring New Electric Range - Grounding Oct 7, 2016
