Grohe ladylux plus
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 39THEO, May 21, 2009.
  1. 39THEO
    39THEO New Member
    May 21, 2009
    The GROHE LADYLUX PLUS faucet is 6 years old. The hot water side is leaking and won't shut off, I shut off the hot water valve. The cold water side works fine,. Can you tell me the part and how to fix the faucet.
    Thanks, Ted
  2. faucetman886
    faucetman886 DIY Junior Member
    Oct 22, 2008
    retired accountant and blogger
    near Atlanta
    TED, like many of the better faucet manufacturers I believe Grohe offers a lifetime guarantee on parts and fixtures. Call Grohe- 1-800-444-7643 customer service describe the problem, provide the model # if you have it maybe digital pic that you can email to them and I believe they will provide you the part you need and/or some trouble shooting help. Let us know how you come out. I for one like to keep tabs on how well these manufacturers live up to their warranties. I know that MOEN is fantastic on theirs and I suspect Grohe will be also. Good luck
  4. hj
    grohe
    You need a new cartridge. Extracting the old one can be somewhat difficult, but installing the new one is easy.
  5. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    The part number is 46 048 000.
    Turn of the water first.
    There is a screw at the bottom of the handle you need an Allan key to remove it, once that is off there is the handle hub which will slide off, under that is the cartridge which is held in place by two screws, once they are remove the cartridge will pull out and then you repeat the process backwards to install the new one.
    Warranty is lifetime as long as you are the original purchaser.
  6. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I've installed quite a few of these
    And yes, the cartridge is the fix.
    Determine if there is dirt/debri in that assembly to see if it is something else causing the problem.
  7. normandy1060
    normandy1060 New Member
    Jan 24, 2013
    Arizona
    I have a Ladylux plus kitchen faucet. It is on a granite countertop. The faucet is loose at the countertop. I want to tighten the faucet to the countertop. I understand that this is done from above, not below.
    I was told to pull the spayer out about 10 to 12 inches, then pull off the spout, then I can get to the part that needs to be tightened. However, my spout does not snap off. I have tried and tugged and pulled, but it only budges about 1/8th of an inch. What can I do to get the spout off?
Similar Threads: Grohe ladylux
Plumbing Forum, Professional & DIY Advice Grohe Ladylux kitchen faucet head Sep 27, 2013
Plumbing Forum, Professional & DIY Advice Repair Parts? Grohe Ladylux plus kitchen hand spray Aug 17, 2013
Plumbing Forum, Professional & DIY Advice Grohe Ladylux Plus Oct 20, 2007
Plumbing Forum, Professional & DIY Advice Tightening Grohe Ladylux Plus Jul 28, 2007
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
