Globe Valve repair or replacement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by crosstalk, Feb 16, 2013.
  1. crosstalk
    crosstalk Member
    Jul 11, 2011
    PA
    Hello. I have a globe type valve that doesn't close completely and looks like it's been dripping a bit from the stem. Is it possible to repair this? Do I remove the stem by unthreading from the valve body (at yellow arrow)?
    I realize that replacing this old valve with a ball valve is the best choice, but looking for a quicker fix. I have soldered valves before but I am certainly not an expert. This valve isolates a bathroom in which the stop valve at the toilet is frozen open so I am going to need to shutoff the whole house at some point to repair this isolation valve or the toilet stop valve.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    It looks repairable. A new washer and tighten the packing nut should do it.
  4. Hackneyplumbing
    Hackneyplumbing Homeowner
    Jul 30, 2012
    Alabama
    + 1 I agree.
  5. hj
    A wiser move might be to replace the vqlve at the toilet.
  6. crosstalk
    crosstalk Member
    Jul 11, 2011
    PA
    Thanks, everyone. Yes, I am going to replace the toilet stop also but thought I should work on this isolation valve if I have to have the whole house shut off anyway. Hopefully this valve won't fall apart on me and create a bigger job!
  7. crosstalk
    crosstalk Member
    Jul 11, 2011
    PA
    Looks like I need more help. I tried to unscrew the stem at the yellow arrow in the photo but couldn't get it to budge. How should I hold back on the valve body so I don't break things? I am starting to think that desoldering and replacing might be the right solution.
    The packing nut is easily turned. Can I replace the washer by removing this part?
  8. jimbo
    jimbo Plumber
    San Diego, CA
    No......................
  9. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    My opinion. The valve may be repairable however, for the price of a new ball valve and the few minutes it would take to install it, why mess around with the repair?
  10. Hackneyplumbing
    Jul 30, 2012
    Alabama
    I would leave the valve alone and use the main outside and then repair the toilet valve. The valve your considering working on is not required. or get your tools out and be prepared to replace it or remove it....IF things go south.
  11. hj
    If it just goes to the toilet, forget about it and replace the toilet valve.
  12. crosstalk
    crosstalk Member
    Jul 11, 2011
    PA
    I just replaced the toilet valve with a new ball type. Works well. I was rewarded with a drip from the stem of the isolation valve--hopefully tightening the packing nut has fixed it. Thanks for all the quick help.
Similar Threads: Globe Valve
Plumbing Forum, Professional & DIY Advice Globe Valve Parts Jun 19, 2016
Plumbing Forum, Professional & DIY Advice globe valve. not gate, not ball. Sep 4, 2007
Plumbing Forum, Professional & DIY Advice Better valve, ball or globe? Feb 2, 2005
Plumbing Forum, Professional & DIY Advice Symmons Temptrol, ID shower valve brand Yesterday at 1:31 PM
Plumbing Forum, Professional & DIY Advice I Replaced Pressure Reducing Valve, leaking? & Pressure Q. Thursday at 11:51 AM
