HomeRepairGuy
Bought a 49" x 22" Glacier Bay cultured marble vanity top with integral basin from Home Depot. Have not installed it yet.
When I test fit the drain pipe, the pipe is not vertical because of how the top fitting seats on the basin. The seat for the chrome ring is a little higher at the back side which causes the drain pipe to be slightly tilted toward the back of the vanity about 5 degrees. IOW, bottom of the drain pipe is closer to the back of the vanity.
I suspect that the drain pipe not being vertical will not allow leak proof connections of the P trap and rest of the drain plumbing to the wall connection. Is that correct or is a tilted drain pipe somewhat common and easily corrected by appropriate drain plumbing?
Thanks,
HRG
Thanks,
HRG
