GFCI Breaker (no GFCI outlets) not working, but not tripped
Discussion in 'Electrical Forum discussion & Blog' started by dmotes, Dec 1, 2010.
  1. dmotes
    dmotes New Member
    Dec 1, 2010
    Olathe, KS
    I don't have any GFCI outlets in my home. Instead, all the bathroom outlets are on the same GFCI breaker. Sometime during the day, I lost power to the outlets on that breaker, but it is not tripped. I hit the reset and clicked it back on, but I still don't have power.
    What are the possible causes of the outage? Thanks in advance!
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    There is no reset button on a GFCI breaker. There is a test button. Did you try moving the breaker handle all the way to the off position then to on position?
  4. jadnashua
    To reset any circuit breaker, doesn't matter the type, you generally have to turn it all the way off, then turn it on. That button on the CB is a test button that you should hit about once a month (like on the receptacles) to verify it is still working properly. It causes the breaker to trip if it is working properly.
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    If you're comfortable with electricity and you know about the risk of arc-flash, run an incand. lamp mounted in a pigtail socket [any hardware store has this socket] from the breaker output terminal [should be a black wire] to the breaker load neutral terminal [should be a white wire] while flipping the breaker handle.
    If no light, disconnect the black wire from the breaker that feeds your outlets and check again for power using the light while flipping the breaker handle.
    Post back with your results.
  6. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    North Carolina
    Are you serious?
    Are you trying to get someone hurt?
  7. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Yes he is!
Similar Threads: GFCI Breaker
Electrical Forum discussion & Blog Distance of GFCI Breaker Apr 26, 2012
Electrical Forum discussion & Blog Two GFCI Breakers in one circuit? Apr 5, 2010
Electrical Forum discussion & Blog Correct wiring of GFCI Breaker Feb 19, 2010
Electrical Forum discussion & Blog Pool tripping GFCI breaker Aug 4, 2009
Electrical Forum discussion & Blog gfci won't reset, dead line wires, lights on breaker still work Mar 15, 2009
