gas water heater runs hot and not
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Kirsten, Sep 2, 2005.
  1. Kirsten
    Kirsten New Member
    Sep 2, 2005
    We have an 8-year-old gas water heater under our house in North Carolina. Two things go on with it that are strange: 1. The water is always hotter from the faucets in winter than in summer (reverse of what we might expect!) and 2. Sometimes for no apparent reason it will run cool for a few hours or a day (max temp from the hottest faucet just over 100F) then it will revert to heating the water normally (up to about 120, except in winter when it gets up to 130+). This happens with no intervention from us. What do you think is going on here, and what can we do about it?
    The WH is insulated with a "blanket" if that matters.
    Thanks,
    Kirsten
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Sounds like buildup on the thermostat inside of the tank; replace the thermostat and this should correct the problem.
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice New hot water heater/pex. Today at 12:27 PM
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
