Gas water heater burner won't lit?
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by Minh422, Aug 25, 2008.
  1. Minh422
    Minh422 New Member
    My water heater pilot light lit! I can hear the gas coming out of the burner unit but it doesn't burn!
    Help?:confused:
  2. Redwood
    Redwood Master Plumber
    7,452
    Please shut it off and call a plumber.
  3. Minh422
    Minh422 New Member
    It was a foreclosed home! Do you think there still air in the pipes?
  4. Minh422
    Minh422 New Member
    It was a foreclosed home and has been empty for 8 months! Do you think there still air in the pipes?
  5. Redwood
    7,452
    Who knows. If gas is coming out and not lighting it could be a dangerous situation. Please call a plumber!
  6. Ronio
    Ronio New Member
    Your thermocouple is bad
    If the pilot actually lights, but wont stay lit after you release the pilot button then your thermocouple is bad. Head down to A*C*E, M*E*N*A*R*D*S, H0me Dep0t and pick up a new one, it will run you about 10 bucks.
    If the pilot just plain doesn't light, you have an issue with your line and may need to have it blown.
  7. hj
    26,510
    heater
    IT should not be air unless the lines were disconnected at some time, but even then it should evacuate fairly quickly. We cannot diagnose your problem from here because we have to see the heater and smell what is coming out of the burner.
Similar Threads: water heater
Plumbing Forum, Professional & DIY Advice, Tips & Reliance 606 water heater keeps shutting off Aug 21, 2014
Plumbing Forum, Professional & DIY Advice, Tips & hot water heaters need to decommission chimney Aug 20, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Leak on water heater supply, inspection report Aug 1, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Bacteria in water heater Jun 29, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Split/Merged Supply to Water Heater? Jun 20, 2014
