Gas LP water heater , can you add temp aux tank
Discussion in 'Water Heater Forum, Tanks' started by dlarson, Apr 15, 2009.
  1. dlarson
    dlarson New Member
    Apr 15, 2009
    I have a Lp gas water heater, would like to add a temp. tank 20lbs ? to fuel my water heater, having problems regarding the regulator, should it be "high"
    or "Low" pressure regulator.. getting many mixed idea's :confused:
    dl
Similar Threads: water heater
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Water Heater Choices Feb 5, 2017
