Beachfront71
Hello and thanks to all.
I bought a Noritz tankless to install in the near future and had a quick question about the gas line w/ regards to feeding the house.
I have a 1" main coming into the house and it goes to the following:
1. 3/4 up to the kitchen for the range
2. 3/4 up to the attic for a 60k btu furnace ..a 75gallon water heater also uses this line for its 3/4 feed
The Noritz is a model 751 which needs 199k btu's per specs..
My question is since the 60k furnace and the 199k Noritz will use the same 3/4 line, is it large enough to handle the requirements?
From the 1" main, the Noritz is only 8 or so feet away, then the line continues up through the first and second floor to the attic for the furnace ... maybe 25 feet from the 1" main to the furnace..
If the single 3/4 does not work, would I just have a plumber splice another 3/4 in the main so the furnace and noritz each have a dedicated line .. or can they share as it is now..
Thanks again.
Thanks again.
