Gas furnace heat exchanger collapse?
Discussion in 'HVAC Heating & Cooling' started by AcidWater, Jan 22, 2014.
  1. AcidWater
    AcidWater New Member
    Oct 14, 2008
    Furnace is running & fan blowing, but very little airflow from the ducts. Could the heat exchanger in my 1966 furnace have collapsed, letting the flow go out the flue?
    Is there a way of removing enough of the front to SEE ? IIRC the maker is Montcrief. Something like that. Would have to check the label...
    I did hear a noice that sounded like something falling down, earlier today.
    The only diagnostic I can think of is to let it run very much too long without getting the temperature up.
    This WOULD happen with record breaking cold and 3 more storm systems being watched...
  2. AcidWater
    Oct 14, 2008
    Well now I know that I don't think very well in the middle of the night.
    The filter was clogged, and it could not draw enough air.
    Filter 4 months old exactly; I usually go 5 months. Maybe extra animal fur due to cold winter ???
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Good that you found the problem.
    Many people change the filter every 30 days, that may be overkill, depends on the blower run time.
    Some of the better T-Stats keep track of blower run time, and tell you when the filter should be replaced.
    Have Fun.
  5. AcidWater
    Oct 14, 2008
    I think I will install a vacuum gage on the plenum to monitor filter loading.
Similar Threads: furnace heat
HVAC Heating & Cooling Converting Garage to living space and water heater/furnace venting req Oct 29, 2013
HVAC Heating & Cooling Heating & Cooling Furnace toronto Oct 10, 2013
HVAC Heating & Cooling hooking hot water heat thermostat to furnace in attic Mar 18, 2013
HVAC Heating & Cooling Confused by Heat Loss Calc - Furnace Size Feb 22, 2012
HVAC Heating & Cooling Why does my forced hot air furnace not heat above 60 degrees? Feb 11, 2012
