I have a wood burning masonry fireplace, with a gas log lighter. The gas pipe coming up through the floor of the firebox apparently contained a nipple that screwed into the female receptacle on the pipe. The nipple broke when I attempted to change the fittings on the log lighter, leaving a broken piece of the nipple inside the female housing of the pipe. The broken nipple looks like 1/2 galvanized ad is receded about 1/2 into the pipe. I will need to remove that piece of nipple to repair things. One problem is that I can't get behind the pipe to hold it in place while I attempt to use force or other means to extract the piece. Can you provide suggestions for it's extraction? Is there any danger in loosening connections to the gas pipe that I would not have access to repair as everything is sealed in brick? Thank you !
