Garage door in RO less than door width?
Discussion in 'Remodel Forum & Blog' started by jrfiero, Jun 19, 2009.
  1. jrfiero
    jrfiero New Member
    Jun 19, 2009
    I'm faced with a problem with narrow wall bracing in a wall with two 9' garage doors and a man door. To provide the required width of the end wall braced panels using the APA method, I will be left with less than 9' ROs for the 9' doors. It strikes me that this is no big deal - the door will be mounted behind the framing anyway (inside the garage). I'm talking about 3/4" on each side.
    Does that sound like a solution? I know I'll have to properly place the 2x6 perimiter band inside the framing for bracket attachment.
    'Course, there's always trimming 3/4 off the doors! But I don't know what material doors I'll be using yet.
  2. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    As long as you don't mind the looks
    3/4" missing from RO
    Then another 3/4" covered over bythe outside trim
    That means you are covering up ~1.5" of the door
    That may look weird
    I put my door on the side of the garage instead of the front to keep my 9' doors. I need the clearance with a truck
  4. AZ Contractor
    AZ Contractor In the Trades
    Apr 21, 2007
    Phoenix, AZ
    Don't worry about it. Its done that way all the time.
Similar Threads: Garage door
Remodel Forum & Blog Garage Door Wall Button Console - How to Open or Remove? (photos) Jul 30, 2012
Remodel Forum & Blog Garage Door Opener The Saga Continues May 14, 2012
Remodel Forum & Blog Garage Door Opener Spring/Trolley Nut Apr 24, 2012
Remodel Forum & Blog Overhead garage door repair - frustration Jan 10, 2012
Remodel Forum & Blog Garage Door Opening Wall 2x4 or 2x6? Aug 11, 2009
