Galvanized Steel Duct for Dryer Ducting
Chefwong
District of Columbia
Any downsides to using galvanized steel ducting for Dryer Ducting ?
I like the heavier gauge of the product, and the fact that it comes in longer runs.
My dryer run is not the most ideal with 2 90 degree bends...it is what is is, but I'm inclined to do the run in the galvanized steel duct material vs the thinner aluminum stock.
Whaddya guys think
Ian Gills
Senior Robin Hood Guy
USA
I used it for that reason too. I doubt it will be as resistant to corrosion as aluminium but hey, it's galvanized.
And so are the fasterners on my deck.
Outside in the rain.
Remember to tape the joints and not use screws.
Also you have to consider that flow velocity is what carries the lint out of the pipe and the larger the pipe/duct the lower the velocity so there will be a faster buildup in the larger duct.
Chefwong
I've yet to find a good trades shop on the plumbing /mechanical side....that was fair to a non trades person......I've got a GREAT electrical supply shop.
I ended up doing the duct run in galvanized 4" round, used mastic as well as rubber buytl (mastic) foil tape. Applied mastic on the *locking seams* as well. It's as air tight as it gets......
On to the next project, which I always despise - painting.
The new BM Aura paint is different...you don't cut with a wet edge. It's like r********* how to paint again.
Ian Gills
USA
My supply house does plumbing, lumber, electrical, landscaping and more....
Chefwong
Heh. There's a great one the further I get out east but we're talking a 2.5 hrs drive...
Unfortunately I survive by using the local boxes but things like paintbrushes, recpetacles, etc I go to the supply shop since that stuff is not *watered down*.
I like buying framing wood at the boxes as I go there early, pick nice straight ones, etc....
quote; I've yet to find a good trades shop on the plumbing /mechanical side....that was fair to a non trades person
And WHY should they be "fair" to a non-trades person? If I had a supply house which was "fair to a nontrades person", I would stop patronizing them, because they would be making it impossible for me to make a living, if the customer could buy things at my cost, so that it would be difficult to add a profit to them. YOU, as a customer, can either buy it at retail from Home Depot or similar, or have me furnish it to you at about the same price.
