Galvanized RePipe- Tight Squeeze on Risers.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JerseyShore, Mar 29, 2013.
  1. JerseyShore
    JerseyShore New Member
    Dec 18, 2012
    New Jersey
    Progressing on re pipe of 1943 two fam... this is why I need PEX as opposed to copper for the risers. It is starting to get a little scarey. Check out stack in first pick. Very tight squeeze in there..... what to do about heating ducts???
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    From what I can see, sweating copper risers should not be an impossible job. Certainly care would have to be taken to protect against fire by having a spray bottle of water within reach and flame guards to keep flame away from the joists. Guess you might have figured out that I'm not fan of PEX.
  4. hj
    I hope you do not think you can make a "square corner" by bending the PEX.
  5. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    Nothing says you have to follow the route of the old pipes.
  6. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    Although not a pro, I'm not a fan of PEX either.
    One thing to consider -- even though fewer joints is less to go wrong, you can always prefabricate sections before installation to get the in-place joints where you want them. For example, if you can get the riser out by undoing the union (background pipe in second picture) then you can get a copper section in just like it...
    Also, they make those fabric heat shields. If you can't afford that, even a couple layers of aluminum foil behind the joint can help some, with the added benefit that it will warn you by a noisy crinkling sound and melting just before the wood catches on fire. Have a good bucket of water and extinguisher handy.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    I have had good result soldering in tight quarters using a opened and flattened #10 can. Usually I cut a notch on one edge so I can slip it around a pipe and bend it a bit to get better coverage when needed. Not as fancy as the story bought fabric heat shield, but works fine.
Similar Threads: Galvanized RePipe-
Plumbing Forum, Professional & DIY Advice Galvanized sink stubout soldered to drain/vent. Or maybe lead piping. Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Galvanized compression coupling Aug 1, 2016
