Karl in NY
I'm planning a DIY marine de-iceing system that will protect a dock from ice conditions, using low-pressure high-volume compressed air to bring warmer, deeper water to the surface, via a series of air holes drilled through 1/2" galvanized pipe. It's a major US lake (Champlain) that has a serious zebra mussel problem, but hot-dipped galvanize acts as a repellent.
My question is in regard to pipe specs.
I need hot-dipped galvanized, and am uncertain if most such pipe is galvanized just on the outside or also on the interior surface diameter as well...
The system will run all winter with a vane-type compressor, essentially low pressure, high volume.
During summer, it will get short daily blasts of 150 PSI air to keep the holes open and to expel zebra mussel larva from the lines before they can attach and breed inside the pipe.
Do typical galvanized steel/iron pipes have their interiors zinc-coated also? Is there a spec. I need to order to insure the zinc coating on both inside and outside, for both the 1/2" pipe and fittings, which will include els, tees, and unions?
Any info. would be appreciated, but I'm trying to avoid grossly expensive stuff like mil-spec piping.
Copper pipe is out due to close proximity to a galvanized submerged rail system that hauls the boat into a boathouse, and it appears that while copper pipe is equally effective against mussels, it will create a galvanic reaction between the nearby dissimilar metals.
Thank you in advance-
Karl.
Karl.
