Galvanized for DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Jul 26, 2006.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    The main run is CI leading up to a 2" female coupler coming out of the floor.
    Have not decided whether I'll be using brass drain *I have a stash of cast brass traps, tubes, etc* or just do PVC all the way the sink. The coupler is about 3-4 inches below the floor ...so if I decide to go the brass route, I do need to stub it out regardless.
    Would galv. be the best material for this application ?
  2. hj
    drain
    There is no "best" material. Use whichever is easiest, or maybe least expensive.
  4. chefwong
    chefwong Member
    Jun 14, 2006
    Is galvanized okay for DWV ? I know gal rusts for water supply.....It's easier for me since they come in all nipple sizes...
    From there I can use the brass traps/tube I do have in the garage now
Similar Threads: Galvanized
Plumbing Forum, Professional & DIY Advice Dielectric union between copper and galvanized pipe Oct 16, 2016
Plumbing Forum, Professional & DIY Advice Brass P-trap and Galvanized Steel Stub-Out Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Leaking galvanized steel pipe in basement Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Galvanized compression coupling Aug 1, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
