Furnace problem- expansion valve leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hurley, Nov 6, 2004.
  1. Hurley
    Hurley New Member
    Nov 6, 2004
    I have an H.B. Smith & Co. furnace that is pretty old. Last year, our expansion valve was leaking water behind the furnace. Our oil dealer came in and drained the expansion tank and replaced the expansion valve. It has lasted almost a year, but now with the cold weather coming, the furnace is working more, and it is leaking again. The expansion tank was full again, and I drained it myself, but the valve is still leaking. Any advice?
  2. hj
    The logical assumption is that you did not drain it properly. The long term solution might be a "precharged" expansion tank, but if so, then you may have to make other arrangements for any air evacuation devices which may have been installed to divert air into your existing tank.
Similar Threads: Furnace problem-
Plumbing Forum, Professional & DIY Advice Washer Floods Into Kitchen Sink & Rerouting Furnace Condensate Drain Jan 26, 2016
Plumbing Forum, Professional & DIY Advice Furnace replacement Aug 14, 2015
Plumbing Forum, Professional & DIY Advice Main water off to house ok with furnace on? Jan 11, 2015
Plumbing Forum, Professional & DIY Advice Running B-Vent for hot water tank and furnace up through center of house. Dec 26, 2014
Plumbing Forum, Professional & DIY Advice Understanding Furnace Drain Dec 2, 2014
