Fuel Oil Water Heater Venting
Discussion in 'Water Heater Forum, Tanks' started by Kielanders, Aug 22, 2011.
  1. Kielanders
    Kielanders New Member
    Aug 22, 2011
    Alaska
    I'm installing a new fuel oil water heater in a home we've just purchased. The unit calls for Type L, which has been difficult to source in my very rural area - and postage from mail order outlets is prohibitive, but may be necessary.
    Question:
    My understanding is that Type L is designed for continuous burn not to exceed 570F, and Double & Triple Wall Stove Pipe is designed for 1000F continuous burn.
    Can I substitute Double Wall Stove Pipe for Type L?
    In either case, I would be using a Tee with a Barometric Damper.
    In an attempt to be ultraconservative, I've already tried to make-work Metalbest Class A Insulated Chimney Pipe, but limitations on fitting angles won't allow for flue connection from the unit.
Similar Threads: Fuel Water
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Today at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Water heating Monday at 7:57 PM
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Monday at 11:17 AM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
