I have a frost free hose bib that worked fine approximately 1 month ago when it was last used - today I tried to use it and although the handle turns out, no water comes out (and temperature has been above freezing for the last month) - several questions:
1) What could be wrong?
2) Is there a fix that can be completed without replacing the entire hose bib? And if so, what is it?
3) If the hose bib needs to be replaced, is there a good solution that does not involve soldering (water lines are copper - hose bib water line is very close to wooden flooring material and between wooden joists)?
