From No Hot Water To No Water At All!!! Please Help!!
Molly Mayhem
Pine Bush, NY
Type of pump?
Submersible____yes____
Two wire (no control)___no_____
Three wire (control box)___yes___
Wire Size___18______ Wire Length_100+ ft._______
or
Jet Pump (above ground)_________
One or two pipes down the well____
Size of Pump?
Motor Horsepower?__________
Pump Model #______________
Date Pump Installed__________
Pumping from?
Cistern tank___________
Pond, lake, river________
Water Well______yes______
Depth of well____60 ft______
Depth to water______5 ft___
Pump Setting__________
Pipe Size_________"
Drop Pipe Material
PVC____yes____
Steel_______
Poly________
Well Recovery Rate___10____gpm
Well Casing Diameter_______6â€
Rock Well______yes____ Sand Well__________ Other______________
Date Well Drilled____1972________
Well Casing Material
PVC_____yes___ Steel_________ Other_________
Pressure Tank?
Bladder or diaphragm tank (one pipe to tank)____yes______
Size or model of tank__SEARS Insulated Glasslined Vertical Water Storage Pressure Tank__________
Air charge in top of tank, with pump off and water drained____________PSI
(check with car tire gauge)
or
Plain Hydro Pneumatic tank (two pipes to tank, one in and one out)_________
Size of tank________________
Pressure Switch Setting?
On 30, off 50 ________
On 40, off 60_________
Other_______________
Pump Control Method?
Cycle Stop Valve model #_________
Variable speed control #__________
Pump Start Relay (sprinkler timer, no tank)_maybe_________
Manually turned on and off____________
Pump Protection
Cycle Sensor_________
Pumptec_____________
Low pressure cutoff switch (lever on side)__________
Filters or Softeners_____no_________
Before or after pressure tank_______
Type of filter___________________
Bypass available________________
Water Used For?
House Use____yes___ Number of baths___2____ Number of People___3_____
High Flow Showers__no_____gpm?
Plus/Or
Irrigation with timers___no_____
Irrigation with hoses__no______
Heat Pump_no_____gpm?
Problems Experienced
No Water____yes_____________
Water only part time________
Water at all times but weak_____
Air in water____yes___________
Pressure surging___________
Water Hammer (noise)______
Too Much pressure_________
Other_______________decline in hot water_____
Pump makes clicking or buzzing sounds________
No Sounds__________no sounds____
Pressure gauge reading___50_____psi
Other____________________________________
Do you have, and know how to use
an Ampmeter and Voltmeter___yes water pump.jpg_______________
Describe Problem__________________________..... I have a submersible pump, and vertical hot water heater. For the last two weeks their was a lot air in my water line, spitting out in all lines, (shower, kitchen faucet, bathroom faucet, etc...). For the past three days I have had a decline in hot water, until (3rd day) their was only cold. Now I have no water at all!! I don't know what the problem is. I don't hear the tank filling up. My sub. pump is fairly new. If anybody has any suggestions; dealt with similar problem PLEASE HELP!!!
DonL
Houston, TX
Have you checked your breakers and breaker box connections ?
You should keep the water heater off, until you can fill it with water, so it don't run dry.
Good Luck.
Craigpump
What are those loose wires for? They look like pump cable to me......
Air in the pipes, sounds like a bad check valve in the pump, or a cracked/broken pipe in the well. Possibly a rotted fitting at the pump.
DonL
Houston, TX
I was wondering the same thing, on the wiring.
Looks like a Electric Heater was replaced with Gas.
Looks unsafe to me no mater what they were/are used for.
Maybe the poster will shed some light.
