French Drain advice
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Daniel S, Oct 24, 2007.
  1. Daniel S
    Daniel S New Member
    May 29, 2007
    O.K. I'm a newbie so please go easy on me.
    I had efforvescence in my concrete basement walls so I got a foundation specialist in my house this morning doing some epoxy/ urethane injections. He mentioned that my french drains are broken but he didn't take the time to inspect the collector pit in the basement. He just told me that the humidity was a sign that my french drain is finished. He is quoting me $85 per linear foot to excavate around the house, install a membrane and install new french drain piping.
    How do I know that it isn't something as simple as it being clogged or something? Would a camera inspection identify what the problem is? I'd like to eliminate all other causes before making any decision to spend several thousands of $$$. What can go wrong with a french drain and what methods of repair are out there??
    Thanks for any advice you can offer.
  2. jadnashua
    If the drains weren't installed in a rock bed, and a soil intrusion mat installed over it, it will eventually fill up with sediment. Once that happens, they don't drain much.
  4. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    I would camera inspect it before digging up all around the house, it could be one area that needs to be repaired $85 for two feet is better than $85 per foot all around the house.
  5. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    French drain???????
    Dang , where's FRENCHIE when You need Him ?? :p
Similar Threads: French Drain
Plumbing Forum, Professional & DIY Advice french drain May 5, 2012
Plumbing Forum, Professional & DIY Advice Laundry Gray Water to French Drain Mar 20, 2012
Plumbing Forum, Professional & DIY Advice Filter Fabric Disagreement on French Drain… Mar 22, 2011
Plumbing Forum, Professional & DIY Advice french drain ???? May 14, 2007
Plumbing Forum, Professional & DIY Advice French Drains/Footing Problems Apr 22, 2007
