found a leak through a hole in the toilet waste pipe
amen
England
hi guys, noticed a leak today and though the 4" toilet waste pipe may have slipped out or something but after investigating I found some poo protruding out of a hole from the middle of the waste pipe! any ideas what could have coused this? could it be a rat chewed through it?? and is replacing the pipe a simple DIY job? I've attached a picture, any input would be much appreciated. Thanks
You talking about that thin plastic, wire-reinforced air duct used as a drain pipe?! If that in fact is a drain pipe, it needs to come out and be replaced with rigid PVC.
Flapper
California
It looks like corrugated plastic, not spiraled wire air duct.
amen
England
Hi, I dont know what it's made from but it's called a back to wall pan connector, so it's made for this purpose I guess, I just dont understand what caused the break in the pipe
WJcandee
Wise One
New York, NY
I take it you are not in the US, because, separated by a common language, we have toilet "bowls" here, not toilet "pans". (And the etymology of that is actually probably at least a little interesting.) And we don't have "back to wall" toilets. We call them "wall hung" or "rear discharge".
What caused the break is unknowable. A crack or break there could be caused by a million things, given the material used and the manner of installation. Typically-permissible fittings in the US wouldn't look like that, perhaps accounting for our members' surprise, and statements above. And the result you have could be seen to validate the stricter US rules...
Would it be a big deal to duplicate that installation as a DIY person? Probably not much, at least as far as the "plumbing" part goes. The removal and reinstallation of the porcelain and perhaps a section of wall might be a bigger deal.
amen
England
You are absolutely right, I am from the UK and just noticed that most if not all members here are from the US.
Yes it seems our standard fitting differ, I have managed to successfully change the connector, this type seems to be the only option available for this type of toilet, I took a closer look at the hole when I took the old connector off and it seems to have been chewed through, the only logical explanation is it was done by a rat, however I've found no droppings or any other sings a rat in the area, which although is good news it still bugs me to not know what exactly happened..
Thanks for all the input fellas! All the best
