fog horn sound melting my sanity-HELP!!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by scott41, Dec 29, 2008.
  1. scott41
    scott41 New Member
    Dec 29, 2008
    I must preface this with the statement that I am a new homeowner and know next to nothing of plumbing repair. I have been experiencing a fog horn like sound from the walls (thinking the pipes) for about a week. Sounds change in frequency, volume and length. For the last two days or so, the sound has been occurring every 3-4 minutes and lasts around 5-10 seconds. I have tried shutting water off to each toilet and faucet with no result. I have tried running water from all faucets/bathtubs for more than an hour with no results. I noticed that water is coming out of one toilet tank slowly leaking into toilet bowl. Need to change rubber stopper and maybe fill valve-although I shut water off to this toilet at the angle stop, the sound continues. I was thinking if this leak was the issue, shutting the water off to the toilet in question would solve problem but it hasnt. I live in townhome and really cant tell which side the sound is coming from, so possibly could be neighbors but I dont know which one. I would appreciate any advice. BTW: sounds dont correlate to flushing toilet, turning on faucet etc. Just seems to occur every 3-4 minutes. Doubt if neighbors are using toilet or turning on faucet every 3=4 minutes.
  2. jadnashua
    If the shutoff for that toilet is an older, multi-turn valve, even when off, it could be leaking. Toilets and valves can make some funny noises. If you flush the toilet with the valve off, does it refill eventually?
    If you have more than one toilet, do you have the shutoff valves fully open?
  4. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    But it could be neighbour's toilet flapper leaking. Have you talked to your neighbours about the noise? They may know exactly what it is.
    My bet is that it is in fact a toilet. If the noise comes every few minutes, you should be able to localize its source some. Try taking the cover off the toilet tank and just watching for 5 mins to see if the level is going up/down and whether the fill valve makes the noise in question.
    You might be able to minimize or eliminate the noise by installing a hammer arrestor somewhere -- if it turns out to be something beyond your direct control such as a neighbour's toilet.
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Where do you live?
    It could be a foghorn you know.:rolleyes:
  6. scott41
    scott41 New Member
    Dec 29, 2008
    to jadnashua: When the valve is on, water visably (and slowly) leaks out of tank down the backside of the bowl. When i flush the toilet with the valve off, it does not refill. I have three toilets and have shut valves off to each one at a time w/ no success. I have since reopened them fully. I know it might be neighbor, but wanted to try everything I could in my place before talking w/ her. Thanks for your reply!
  7. Cass
    Cass Plumber
    Nov 12, 2005
    It may be and I would closely look at 3 things...a pressure reducing valve if you have one, your water meter if it is inside the house, or the toilet. The toilet includes the stop, supply line, and fill valve...I have had all of the above mentioned items cause niose...water constantly flowing from tank to bowl would be the flapper in need of replacement long as the water in the tank is not overflowing into the over flow tube...
  8. scott41
    scott41 New Member
    Dec 29, 2008
    Problem solved
    To all: Problem solved and my sanity saved. It was the neighbors toilet!! Thanks to all who tried to help me. Scott
Similar Threads: horn sound
Plumbing Forum, Professional & DIY Advice Need help with Fog horn sound when water is running! Jan 7, 2013
Plumbing Forum, Professional & DIY Advice Another wining to fog horn sound Jul 2, 2009
Plumbing Forum, Professional & DIY Advice loud foghorn sound when hot water faucet is turned on Aug 20, 2008
Plumbing Forum, Professional & DIY Advice Replace valve post-meter horn Mar 8, 2015
Plumbing Forum, Professional & DIY Advice fog horn pipes Feb 5, 2008
