Floor mounting ring
Discussion in 'Toilet Forum discussions' started by balld, Jun 30, 2006.
  1. balld
    balld New Member
    Jun 30, 2006
    I'm not sure of the correct terminology, but my new house with roughed in basement bath has this ring installed rotated 90 degrees from the correct orientation. The current setup would have the flange bolts attaching at the front and back instead of the sides. How can this be corrected properly?
    Don
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Is the flange connected to 3" or 4" pipe?
  4. jimbo
    jimbo Plumber
    San Diego, CA
    What is your flange made of? Some have a metal ring which swivels for proper orientation.
  5. balld
    balld New Member
    Jun 30, 2006
    Commode Flange
    The flange is made of plastic and is embedded in concrete. It won't swivel. I did discover that it has two indentions in the correct orientation that may work in a pinch as the flange bolt will slide into them. Photo is attached.
  6. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Ok, If it's square, go for it.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I see no reason why you can make it work, the tee bolts have a wide enough head to hold in the slot. However, since it is a new house, why not make the "plumber" who set the flange come back and make it right? You paid him for a professional job, demand that it be a professional job.
Similar Threads: Floor mounting
Toilet Forum discussions Caroma Sydney Rear Outlet Floor Mounting Oct 1, 2015
Toilet Forum discussions Replacement toilet with floor supply behind commode Yesterday at 9:53 AM
Toilet Forum discussions Wall concealed tank / floor mount toilet Mar 12, 2017
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Sani Seal with Offset Flange 1/4" Above Tile Floor Jan 5, 2017
