Fleck 7000 Problem
ArayT
Middle Georgia
Got it fixed!! Idiot me mistook the PM light for the flow light.
Need advise on programming valve. I Try to enter extended program mode (via v^ simu for 5 seconds at 12:01pm) the programming light comes on, I push the extra cycle botton and A-10 displays. The up and down allows me to changes this. Now the problem I push the extra cycle button again and it brings be right back to the time. It will not let me continue. Any advise would be appreciated.
Thanks, Ray
Akpsdvan
Alaska
Which control is it that you have?
The first generation was red read outs, the second generation is of an LCD read out, black on a greenish background?
Neither have a lock out ...
It is possible that you have gotten in a loop of sorts and there is a way of a Master Reset to factory settings.. once that is done you would need to reprogram the settings for default days , backwash time and the rest of the settings that where set for your water and useage.
