Fleck 2510SXT Settings Check New Install
Drowe218
First time poster, long time reader. Thank you all for the valuable info over the years here. I finally have a question, unfortunately it’s been beat to death here already but my math isn’t mathing tonight.
Fleck 2510SXT 96k system capacity(oversized for future human resource expansion with the wife)
38 gpg hardness, 0 iron
Typical usage for a 2 person household
Looking for future proof settings for balance between salt usage and having soft water
What do you experts suggest changing?
-DF/Gal
-VT/dF1b
-CT/Fd
-NT/—-1
-C/96 (this I’m not sure but think lower?)
-H/38 (This if my math is correct should be 46?)
-RS/SF
-SF/15 (thinking of changing this to 7%?)
-DO/14 (I’d like to change this to longer?)
-RT/12:00am
-BW/10
-BD/60
-RR/12
-BF/30(I know this needs changed as well but not sure to what?)
-FM/t0.7
96K is a marketing term for 3 cuft Do not use that for calculations.
Do you know what number/color of injector you have?
Critical-- what BLFC do you have? The 5600SXT commonly has 0.5 gpm, but I don't know if that is the case with 2510SXT
Drowe218
Is this something I can see now that it is installed? I will go look if that is the case.
:edit: Ok, I was able to verify that it is the 0.5 gpm BLFC
Based on my reaserch here I believe I should use:
C- 72
H- 46
BF- 16
SF- 7
SPECIAL System info (not programmed)
salt lb/cuft : 7 ; A choice ( efficiency vs capacity)
BLFC : 0.5 ; Brine Refill rate GPM
cubic ft resin : 3.0 ; Same as (nominal grains/32,000)
Raw hardness : 38.0 ; including iron etc
Estimated gal/day 120.0 ; 60 gal per person typical calc
Est days/regen 12.06 ; presuming days each use reserve capacity
Fleck 2510SXT SPECIAL Settings:
DF = Gal ; Units
VT = 2510 ; Valve type
RF = dF2b ; Downflow, Double Backwash
CT = Fd ; Meter Delayed regen trigger
C = 67 ; capacity in 1000 grains
H = 46 ; Hardness grains after comp factor
RS = rc ; rc says use gallons vs percent
RC = 120 ; Reserve capacity gallons
DO = 30 ; Day Override (typ 28 if no iron/Mn)
RT = 3:00 ; Regen time (default 2 AM)
B1 = 6 ; Backwash 1 (minutes) [3...10]
Bd = 60 ; Brine draw minutes IF injector is #2 blue or #3 yellow
B2 = 4 ; Backwash 2 (minutes)[3...10]
RR = 6 ; Rapid Rinse minutes [5...10]
BF = 14 ; Brine fill minutes
FM = t0/7 (usual) ;
DO = 30 ; Day Override (typ 30 if no iron/Mn)
RT = 2:00 ; Regen time (default 2 AM)
B1 = 5 ; Backwash 1 (minutes) [3...10]
Drowe218
DF = Gal ; Units
FM = t0/7 (usual) ;
Is there a benefit to the double backwash as opposed to the single it’s currently set to?
Bannerman
Ontario, Canada
Double backwash is most beneficial and recommended when using a lower salt setting that equates to less than 6 lbs per ft3 of resin.
For the recommendation above, the 14-minute BF setting X 0.5 GPM BLFC rate = 7 gallons fill. 7 gallons X 3 lbs salt dissolved per gallon = 21 lbs total to regenerate 67,000 grains usable capacity per cycle.
21 lbs / 3 ft3 = 7 lbs per ft3 of resin. Double backwashing will consume additional water with minimal benefit realized.
index.php
