fixing wall that bows out past door frame
Discussion in 'Remodel Forum & Blog' started by cam100, Feb 8, 2010.
  1. cam100
    cam100 New Member
    Aug 12, 2009
    After installing a pre-hung steel door, I found that the interior wall bows out past the door frame. At the highest spot, about halfway down the wall, the drywall bows out about 3/8"" past the frame. How should I install the moulding around the door frame? Should I try to shave down the wall or build up the edge of the door frame in that area with some kind of filler to bring it level with the drywall?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It sounds to me like poor wall framing. Perhaps a crooked 2x4? In my opinion, I think your best fix is to remove some drywall and correct the cause of the problem rather than hack a cover-up. One of the "joys" of building projects is working with warped or bowed lumber!
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I've taken down casing around several doors to find that the installer cut away drywall to make it lie flat. If it's too bad, pull it apart and replace the offending studs and drywall.
Similar Threads: fixing wall
Remodel Forum & Blog Fixing a wall Jul 10, 2006
Remodel Forum & Blog Fixing someones mess! Jun 21, 2011
Remodel Forum & Blog Fixing a bowing ceiling Jun 21, 2009
Remodel Forum & Blog Fixing dryer vent by drilling hole in a beam May 8, 2009
Remodel Forum & Blog Fixing a crack in poured foundation.... Feb 8, 2009
