Fixing a wall
Discussion in 'Remodel Forum & Blog' started by Cookie, Jul 10, 2006.
  1. Cookie
    Cookie .
    Oct 7, 2005
    Hi, I got a question about fixing a wall. I think they are drywall. I am not sure. But, when the roof leaked it cracked the top covering to the wall. So, I scrapped it off and several layers of paint came off. I wonder, if I did right to fix it. I used spackling. And, I smoothed it on, not really thick, and now it is drying. Please tell me, if this is right?
  2. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    There are many different spackling products out there. I use the Dap vinyl spackling paste for most cracks and holes in drywall and just about every other material. It doesn't shrink, it's strong, it's somewhat flexible, and it sands easily. You just need to stir it a little more than the dryer spackles, since it tends to separate when it's sitting on the store shelf.
    As for the ceiling tiles, I would try to clean them first with some kind of degreaser (diluted) and see if that works. If they are stained really bad, you may need to use a stain blocker, like kilz. Stainblockers now come in spray cans that spray upward.
    Eric
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I find it too runny for my tastes. Maybe I'd just rather use too much at one time. :)
  5. jadnashua
    The moisture stain will bleed through the spackling. A stainblocking primer (there are various ones out there, as mentioned Kilz is a decent one) will seal that stain in, and allow a nice finish coat.
    The bigger problem is if it was drywall, is that if wet long enough, it will cause the drywall to swell, the paper to bulge, and become soft. If yours is solid, then the primer and then finish coat should work.
    One thing that I used that I found really seems to work is a paint addative made by www.insuladd.com. It is basically mini (like flour) hollow ceramic spheres you mix into paint. It actually makes an insulating radiant barrier, that has surprising properties. It gives the paint a little texture, makes the paint thickness a little greater, and covers minor surface imperfections. The ceramic is the same material that's on the bottom of the space shuttle. Neat stuff. I used it on all the walls on my first floor remodeling, and will be using it on the ceilings of the upstairs when I get around to it.
  6. jadnashua
    Plaster should be fine with what you've done. The plaster has wood lath behind it (in all likelyhood). When that gets wet, the wood, dirt, etc., will leach out of that and can cause a stain. Once you get it smooth, use the stain blocking primer, then finish.
    You can use that stuff in both interior or exterior walls/ceilings. It just depends on making sure you mix it into the right paint for the job. You need to have a big enough pail to mix it into...it doesn't disolve, it increases the total volume. You can buy paint with it already mixed in, but you aren't buying as much paint per gallon (and thus covereage), since some of it is displaced by the ceramic. Read up on it, and then decide. If the ceiling isn't towards the attic, it probably isn't worth the effort.
  7. Verdeboy
    Jun 12, 2006
    You just have to mix it up good. I just repaired a fifty foot crack in a ceiling with it and it didn't run at all. What bugs me are spackles that get all crumbly.
  8. Verdeboy
    Jun 12, 2006
    You'll know you fixed it right when, after it is sanded, the area is as smoothe as a baby's behind and blends in with the rest of the wall, with no lines or seams. An exception is if the plaster has a "swirly" texture to it. If it does, you can swirl the taping knife while the spackle is still wet to create this same texture. As I mentioned before, the vinyl spackle paste is wonderful for plaster as well as for drywall repairs. Because it's a paste, you can easily use your taping knife to swirl it, as I just mentioned.
    Don't worry about the brown stain bleeding through. When you're satisfied with the repair, just brush or spray on some kilz, let it dry, and then paint it to match.
    1 person likes this.
  9. prashster
    prashster New Member
    Dec 7, 2005
    Sleepless in Seattle
    Hey, I'm a sucker for a romantic movie too. But come on, don'tcha just wanna puke at the mere mention of the words "Tom Hanks" and "Meg Ryan" in the same sentence?
  10. jimbo
    jimbo Plumber
    San Diego, CA
    Lets back the truck up. Based on what you said, you have sheetrock and the paper layer has peeled off. I do not consider this repairable. Spackling does not bond well to the internal gypsum layer. The brown color you see is most likely staining from the leak problem. You may be able to block this with enough coats of Kilz. But, the proper way to fix this is to cut out all the damaged areas and put up new sheetrock.
Similar Threads: Fixing wall
Remodel Forum & Blog fixing wall that bows out past door frame Feb 8, 2010
Remodel Forum & Blog Fixing someones mess! Jun 21, 2011
Remodel Forum & Blog Fixing a bowing ceiling Jun 21, 2009
Remodel Forum & Blog Fixing dryer vent by drilling hole in a beam May 8, 2009
Remodel Forum & Blog Fixing a crack in poured foundation.... Feb 8, 2009
